Automatic installation of Autoswitch on HiveOS
This script is designed to automatically install the autoswitching program for nicehash.
The autoswitch program this script installs is by @lexandros
I made this script primarily to help myself deploy autoswitch fast.
However I feel I should share this script so others can more easily set up autoswitch.
When running this script, the script will ask for your HiveOS API keys.
Then the program will ask for the hashrate benchmarks for each supported algorithm
The data will be entered into autoswitch.conf file
Once autoswitch is configured the script will ask the user if they want to start the program.
For a guided installation enter the following 3 commands
wget https://raw.githubusercontent.com/CryptoLuigi/autoswitch_autosetup/master/autoswitch_autosetup.sh
chmod +x ./autoswitch_autosetup.sh
For automatic installation enter all the required arguments
Example usage
./autoswitch_autosetup.sh APIkey(1) keccak(2) nist5(3) neoscrypt(4) lyra2re(5) lyra2rev2(6) ethash(7) skunk(8) cryptonightv7(9) cryptonightheavy(10) lyra2z(11) x16r(12) cryptonightv8(13) mtp(14) cuckaroo29(15) cryptonightr(16) cuckaroo31(17) lyra2rev3(18) zhash(19) beam(20) y(21)
./autoswitch_autosetup.sh dfgdfgfdsg 0 278 0 0 0 0 195 0 0 0 110 0 15 33 0 0 0 0 0 y
Last [y/n] is if you want to start up autoswitch now
Just using my imagination here but…
It is very possible to add this into the web GUI if HiveOS would like to add it in.
The file would have to added in HiveOS an update.
Firstly,
HiveOS web interface should allow a single Nicehash wallet to be used for any Nicehash Algo.
Instead of having to create a wallet for each Algo.
With that enabled it would be easier to add in autoswitch directly as a baked in feature.
In the flight sheet page, when adding a new flight sheet, if the user types in nicehash
then click on "Nicehash-Autoswitch" and new window would pop up.
In the new window on the top there would be a toggle for AMD or Nvidea.
This toggle would use the best miner for that card on there respective algo.
Next to that would be location, This would setup the proper pools.
Under that would be 19 check boxes for each algo
Keccak: [ ] Ethash: [ x ] Zhash: [ ] Nist5: [ ] LyraREv2: [ ]
When the user checks all the algos they want use on nice hash.
They will hit the save botton.
This will auto-generate all the desired flight sheets.
When the user goes to select a flight sheet to push to a miner.
The option Nicehash-Autoswitch would appear as a special flight sheet.
A window would open when selected
The window would have 19 fields for each bench mark
Zero indicates that autoswitch wont use that algo.
And probably instead of showing all 19 fields, the UI can and should only show the ones previously checked.
Keccak: [ 0 ] MHs Ethash: [ 240 ] MHs Zhash: [ 0 ] Mhs Nist5: [ 0 ] MHs LyraREv2: [ 0 ] MHs
And the last field would be for API key.
User selects confirm
The server than has all the information to push autoswitch without going into terminal.
Just ideas ;)
If you encounter any bugs with the install script please leave a comment with details.
Here is a video tutorial if you need further elaboration.
