I tried dual mining using zilpool (I think that was name of it) and Sparkpool. I entered my account name instead of my wallet as I use account mining on sparkpool to scoop up their interest they pay on holding your eth. When I do this zilpool closes me down saying invalid wallet address as it doesnt seem to accept account mining on sparkpool. Its strange they need to validate my eth wallet as I am just switching to that pool for zil. Did you have any luck using dual mining that supports account mining on sparkpool?
hey. I havent Managed to get this working, tried only few times tho⦠In team Red miner latest there is new support for set dual mining for eth Zil⦠Just can get into my head what are the in conf arguments that are reguired⦠even there is a good guide for trm. I anyone who have set up this new Trm dual can take the time and show how to flightsheet. dont really get it that it goes with only one miner⦠so required arguments for connect zil server and wallet, epoch etc are all in eth trm flightsheet?? Total noob in dual mining⦠For others not so
Hi All,
Iāve managed to get the ETH+ZIL mining wirking on TeamRedMiner (Lastest version)
With HiveOS (Lastest version)
here you can see my config:
after selecting which GPUs will be working on this configuracion (-d 0,2,3), you have to add the following argument:
āzil -o stratum+tcp://eu.ezil.me:5555 -u ETHWALLET.ZILWALLET.%WORKER_NAME% -p x --zil_end
NOTE: replace ETHWALLET and ZILWALLET with your ETH and ZIL wallets.
Example:
āzil -o stratum+tcp://eu.ezil.me:5555 -u 0x68cb343bf7c79598dcd6c317cb27930000000000.zil1mq1tp21thas3r2hd0sceg7m54qm40000000000.%WORKER_NAME% -p x --zil_end
remember to separate both wallets with a dot.
thanks, so system wil pick up worker name with config"worker name "or is that ref that u need to add the actual worker name⦠feel stupid even asking but still have doubt, have tried so many setup⦠
Well, I added %Worker_Name% argument, but I think if you add any name the pool will show it anyway.
In my case, itās picking up my worker name from hive.
tried your config and all looks fine. but after 3 times mining zil on shradpool my worker went offline for the zil pool. Eth mining on ethermine works fine.
did you have same expirience?
You mean you canāt mine ZIL at all after those 3 rounds?
If so, no, Iām mining normally. 1 ZIL round after 100 minutes.
I donāt know about shard pool because Iām using Ezil pool
any Gminer setting here?
binance + ezil possible??
Thank for config TeamRedMiner
Do you have config for PhoenixMiner too?
best regards
Hi @Kenshinji
I donāt have any Nvidia card to try, but here is what I found on Google, hope it works for you:
Is a post in medium.com site explaining how to mine ETH+ZIL with a few miners.
anyone have the configs for NBminer for ETh+Zil i farm Eth in hiveos pool!!!
tnx!!!
i want also this config eht on hive and zil in ezil.me, i have try alot of things and dont work
Have you managed to get it work on phoenixminer on hiveos?
Not yet
Thank you for all your doing lol. I finally figured out t rex⦠and been running the old trm algorithm. Im about to try this. my one question, what about the defalt wallet and pools? Are you setting them normalā¦eth.zilā¦and then the pools?
thanks, i ended up leaving the cards and pools in the fs
ya i got it working, trm, wouldnt run on shard, but is running fine on ezil. and the t-rex is running well on shard⦠going to let them run for a day, then maybe try to get both on the same pool
Just wanted to give back to the community and show you a working configuration with a rig running both teamredminer and trex. Mining Eth to Hiveon Pool and Mining Zil to shardpool.io
Hope this helps other folks!
Volevo indicarvi il dual miner ETH+ZIL ETH su pool hiveon e zil su pool ezil.me
Con Iolminer x le gpu Nvidia
E per le amd Team red miner
Funziona al 100 x 100!!!
Buon lavoro e buon mining a tutti.
Thank you very much. This was really helpful.
