варианты обновления:
- для обновления из командной строки: custom-get <путь> -f
- удалить папку с майнером через файловый менеджер тогда закачается апдейт из того что в веб прописано
пока так только
пока так только
Привет.Будь добр поподробней-в чем было дело.Третьи сутки кроме "unknown miner custom"ничего не выходит.
Как установить/запустить файловый менеджер?
Установил/запустил Nautilus.
mc - Midnight Commander уже установлен
лучший консольный файловый менеджер
If possible, can you change the order of the arguments being passed to cryptodredge so that they are more configurable?
Right now, you have:
./CryptoDredge $(< $CUSTOM_CONFIG_FILENAME) --log $CUSTOM_LOG_BASENAME.log -b ${WEB_HOST}:${WEB_PORT}$@
If you change it to:
./CryptoDredge --log $CUSTOM_LOG_BASENAME.log -b ${WEB_HOST}:${WEB_PORT} $(< $CUSTOM_CONFIG_FILENAME)$@
Users can change the API port to something other than localhost in ‘Extra config arguments’. Cryptodredge seems to accept the last occurance of a command line argument, so this lets people override everything.
Logfile and API are used by HiveOS. If user override it, he won’t get statistics at web face.
Right!
My intentions were to change the API port, though. “127.0.0.1” is too restrictive, which makes it so you can’t use anything other than Hive for monitoring. I wanted to change it to “0.0.0.0” so I can query cryptodredge, but I’m unable to change it because of the last “-b” argument.
A post was merged into an existing topic: [REQUEST] Miners for adding to HiveOS | Майнеры для добавления в HiveOS
I’m sorry, but we decided to keep the current order of the arguments according to the interests of the security of other users.
The good news is that all integration scripts are open, you can change it as you want.
Can anyone help me integrate the X22i algo miner for SUQA coin with HiveOS? I have tried to add this miner as a custom miner and it didn’t work for me. I dont know how to start the miner after installation. I couldn’t find any clear guides on how to do that. https://github.com/zjazz/zjazz_cuda_miner_experimental/releases
I have installed the v9.1 cuda.
Thank you!
Hi to All
I have made sgminer integration as custom miner everything work ok except miner statistic in HiveOS.
Miner show only total Mh/s but no separate GPU statistic !!!
h-stats.sh file:
#!/usr/bin/env bash
 . /hive-config/wallet.conf
API_TIMEOUT="15"
stats_raw=`echo '{"command":"summary+devs"}' | nc -w $API_TIMEOUT localhost 4028`
if [[ $? -ne 0 || -z $stats_raw ]]; then
echo -e "${YELLOW}Failed to read $miner from localhost:4028${NOCOLOR}"
else
khs=`echo $stats_raw | jq '.["summary"][0]["SUMMARY"][0]["KHS 5s"]'`
stats=`echo $stats_raw | jq '{khs: [.devs[0].DEVS[]."KHS 5s"], temp: [.devs[0].DEVS[].Temperature], \
fan: [.devs[0].DEVS[]."Fan Percent"], uptime: .summary[0].SUMMARY[0].Elapsed, algo: "'$CUSTOM_ALGO'"}'`
fi
[[ -z $khs ]] && khs=0
[[ -z $stats ]] && stats="null"
HiveOS command: agent-screen show statistic, but in RIG page only total Mh/s:
Wed Oct 10 13:48:59 EEST 2018
Hashrate custom 51940 kH/s
{"method":"stats","jsonrpc":"2.0","id":0,"params":{"rig_id":"*****","passwd":"*******","miner":"custom","meta":{"custom":{"coin":"GEEK"}},"miner_stats":{"khs":[8616,8594,9213,8693,8578,8686],"temp":[62,61,62,62,62,62],"fan":[65,80,100,80,61,85],"uptime":92128,"algo":"geek"},"total_khs":"51940","temp":["62","61","62","62","62","62"],"fan":["65","80","100","80","61","85"],"power":["111","117","132","107","105","107"],"df":"429G","mem":[3897,733],"cpuavg":[0.14,0.1,0.09]}}
OK
Wthat I do wrong ???
Link to custom sgminer GeekCash custom miner for HiveOS 2.0
Для нвидиа есть добавьте пожалуйста ))))
нечем зелень тестить…
Я могу протестить))
в кастомный майнер сылка с Github не будет работать как я понял?
конечно будет. только управлять надо будет ручками  и никакой статы и прочих преимуществ нормально интегрированного майнера у Вас не будет.
Понятно спасибо за ответ. Ещё один вопрос есть в планах добавить этот майнер ? и когда ?
