run command:
custom-get http://download.hiveos.farm/custom/phoenixminer-3.5_c.tar.gz -f
ничего не изменилось
Ну чо-то поменяли. У меня стал писать температуру карты, которой раньше не писал.
Напомни, какие у тебя проблемы остались?
не запускается на 73 образе с драйверами 18.20
Unable to open log file /var/log/miner/phoenixminer/lastrun_noappend.log - 2
No OpenCL platforms found
No avaiable GPUs for mining. Please check your drivers and/or hardware.
custom phoenixminer exited, waiting to cooldown a bit
так на 57м же запустили. Или гонешься за цифрамим в номерах версий?
У меня ваще 73й при загрузке уходит в кернелпаник.
I’ve changed API port for Phoenix, so now it can be one rig with Phoenix and Claymore runned simultaneously.
с логами проблему исправили, а вот с остальным, похоже, нет. В 57 образе с апдейтом до 74го, феникс 3.5с работает.
I cound’t add custom miner for ETH
How can you do?
testing now! same config for each setup, 2x570s and 2x580s — I let them autotune hence why they are showing slightly different hashrates.
I`d updated the driver to amdgpu-pro 18.10. The number of stale shares decreased! Reported hashrate become a little higher.
oops! forgot to do that – fixed now.
Thanks for reporting on the new drivers! I’ll update after this 24hr comparison run.
recommend instead of
echo "-mport $WEB_PORT" >> $CUSTOM_CONFIG_FILENAME
in h-config.sh
and
WEB_PORT=3335
in h-manifest.conf
just change global_config.txt to:
#DONT EDIT THIS FILE, IT WILL BE OVERWTITTEN AFTER UPDATE
#Management port, readonly
-mport 3335
#Log to the same file
-logfile /var/log/miner/phoenixminer/lastrun_noappend.log
the rest of the options in there are not implemented yet (HW control) or are not the correct syntax for Phoenix… -r in Phoenix is -rmode
#run reboot.sh on GPU hangs
-r 1
#Target temp
-tt 68
#stop GPU temperature
-tstop 82
-allpools 1
I am running without a -tt option and it works fine (using HiveOS autofan)
Thanks, I’ll fix it in next release.
T-Rex NVidia GPU CUDA 9.1/9.2 miner package
скажите при обновлении майнера достаточно ли изменить путь или надо удалять старый надо
