and this is the error i get
Miner reports that your config broken by NVidia settings
replace NVidia
"gpu_threads_conf" : [], "platform_index" : 1,
Thank you, that’s ok now, here is my amd.txt overrite for those who need it :
“gpu_thread_num” : 2,
“gpu_threads_conf” : [
// gpu: Ellesmere memory:8160
// compute units: 36
{ “index” : 0, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 1, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 2, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 3, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 4, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 5, “intensity” : 808, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
“platform_index” : 0,
HI Everyone.
I like  to starting to mining  loki, I have 6  rx 580 4gb and 1 rx570 4gb
can some help me with the configuration.
I know that Thierry_MArc  show his config but he have rx 580 8gb, mines are 4gb.
thanks,
I  use the same configuration show up, and I am getting this issue.
Can some one please help me.
Thank you
@pinedalrober Check your config file.
If you copy/paste from web for example then double quotes maybe replaced or on the same  spirit
Thanks man for replying,
I am not an expert on mining, but this is my config, what would you suggest me to change
This is my config
“gpu_thread_num” : 1,
{ “index” : 0, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 1, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 2, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 3, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 4, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
{ “index” : 5, “intensity” : 496, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 2, “comp_mode” : true },
@pinedalrober XMR-Stak config contains 4 fragments - general, AMD, NVidia and CPU
Something wrong with your general config where pool (or pools) url and port.
Никак не получается настроить майнинг RYO в соло. идут реджекты от пула https://ryo.solopool.org/#/help
Т.е. то что у вас в конфиге нужно догадаться?
Что не так я сделал?
