Ccminer forks
Hi , how can i mine PigeonCoin (algo X16S ) with hiveOS please ??
[quote=“NicoRig;1974”]Hi , how can i mine PigeonCoin (algo X16S ) with hiveOS please ??
[/quote]
http://forum.hiveos.farm/discussion/435/request-miners-for-adding-to-hiveos-maynery-dlya-dobavleniya-v-hiveos#latest
This is a standard Hive install, why is this not working?
I followed these instructions from above:
cd /hive/ccminer223-cuda90
wget http://download.hiveos.farm/ccminer/cuda9/ccminer-alexis
miner stop
mv ccminer-alexis ccminer-generic
chmod +x ccminer-generic
miner start
Try to run it and get missing file error:
root@mamiya1:/hive/ccminer# ccminer-generic
ccminer-generic: error while loading shared libraries: libcudart.so.9.0: cannot open shared object file: No such file or directory
root@mamiya1:/hive/ccminer# find / -name libcudart.so.9.0
Unable to find the above file.
Always some shit needs to be “fixed” or modified or missing in Linux systems, no wonder people stick with windows.
root@mamiya1:~# selfupgrade
Ign:1 https://hive.kgroup.biz/repo/binary InRelease
Ign:2 https://hive.kgroup.biz/repo/binary Release
Ign:3 https://hive.kgroup.biz/repo/binary Packages.diff/Index
Ign:4 https://hive.kgroup.biz/repo/binary Translation-en_US
Ign:5 https://hive.kgroup.biz/repo/binary Translation-en
Ign:6 https://hive.kgroup.biz/repo/binary Packages
Err:6 https://hive.kgroup.biz/repo/binary Packages
SSL: certificate subject name (.hiveos.farm) does not match target host name ‘hive.kgroup.biz’
Reading package lists… Done
W: The repository ‘https://hive.kgroup.biz/repo/binary Release’ does not have a Release file.
N: Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch https://hive.kgroup.biz/repo/binary/Packages SSL: certificate subject name (
E: Some index files failed to download. They have been ignored, or old ones used instead.
nan
подскажите
при включении любого алгоритма на ccminer
работает только алгоритм neoscrypt
как поправить чтоб работал указанный алгоритм в настройках кошелька?
How to set the difficulty to static difficulty? Since the hashrate on hive os has a huge difference with the hashrate on pool site. Thanks!
i couldnt mine on x16R algo. is there any special oc setting for it ?
pls update suprminer and enemy miner in the next update
CCminer fork ennemi 1.05 is out, is it possible to add it please. Thank you.
By the way, felicitations for this great software.
Please update suprminer to 1.6: https://github.com/ocminer/suprminer/releases
wich miner fork is verge x17 algo ?
Please add Enemy 1.08 miner
Enemy 1.08 broke being able to access the API externally. HIVE has the following hard coded it seems:
“api-bind”: “0.0.0.0:4068”
According to the Enemy 1.08 dev, it needs to be:
-api-remote and/or --api-allow= ( simple 0/0 )
Adding either of the above as extra arguments in the HIVE GUI gets ignored.
The fix was to add:
“api-allow” : “0/0”
under extra arguments after all.
So what about sp-mod ? Is it works?
I have added “api-allow” : “0/0”
But I keep getting
“Failed to read ccminer stats from localhost:4068”
Web showing no hash and no GPU temp
What did I do wrong?
There’s a new x16r miner by SP:
Open source, no dev fee, as fast as Enemy 1.08.
Please add the new Enemy miner update. 1.09 was just released.
Несколько дней методом тыка пытаюсь подобрать форк под той или иной алгоритм. Есть ли где инфа поконкретнее? Что-нибудь вроде таблицы или списка с подходящими для разных форков алгоритмами
