Ccminer forks
Yup sp-mod does not work
Bcd mod dsnt have “bcd” algo in web-panel. Plz add algo to web-panel
Нет в панели алгоритма bcd, приходится править wallet.conf, что не есть хорошо
2018-02-11 02:34:32] Non-existant CUDA device ‘11’ specified in -d option
ccminer exited, waiting to cooldown a bit
any ccminer fork i choose besides ccminer-tpruvot
only ccminer-tpruvot works!!!
also:
in ssh
18-02-11 02:37:12] GPU #2: GeForce GTX 1080, 46.70 MH/s
[2018-02-11 02:37:13] GPU #7: GeForce GTX 1080 Ti, 56.35 MH/s
[2018-02-11 02:37:13] GPU #4: GeForce GTX 1080 Ti, 56.17 MH/s
[2018-02-11 02:37:16] GPU #0: GeForce GTX 1080 Ti, 58.21 MH/s
[2018-02-11 02:37:18] GPU #10: GeForce GTX 1080 Ti, 57.20 MH/s
[2018-02-11 02:37:18] GPU #4: GeForce GTX 1080 Ti, 55.49 MH/s
[2018-02-11 02:37:19] accepted: 8/8 (diff 2.566), 462.01 MH/s yes!
[2018-02-11 02:37:19] GPU #11: GeForce GTX 1080 Ti, 47.21 MH/s
[2018-02-11 02:37:19] GPU #9: GeForce GTX 1080 Ti, 44.81 MH/s
[2018-02-11 02:37:20] GPU #5: Gigabyte GTX 1080, 35.42 MH/s
[2018-02-11 02:37:20] GPU #3: GeForce GTX 1080 Ti, 46.98 MH/s
[2018-02-11 02:37:21] GPU #7: GeForce GTX 1080 Ti, 56.33 MH/s
[2018-02-11 02:37:22] GPU #2: GeForce GTX 1080, 46.29 MH/s
[2018-02-11 02:37:24] GPU #0: GeForce GTX 1080 Ti, 59.44 MH/s
[2018-02-11 02:37:25] Stratum difficulty set to 650.481 (2.54094)
[2018-02-11 02:37:26] GPU #10: GeForce GTX 1080 Ti, 58.15 MH/s
works but not in webpanel… it does not display anything.
Здравствуйте!
Вот такая ошибка на данном майнере, майнер далее зависает, ничего не происходит
[2018-02-27 22:03:56] Stratum difficulty set to 0.3
[2018-02-27 22:04:03] GPU #4: Gigabyte GTX 1080 Ti, 34.98 MH/s
[2018-02-27 22:04:03] accepted: 352/354 (diff 0.391), 230.37 MH/s yes!
[2018-02-27 22:04:14] GPU #2: MSI GTX 1080 Ti, 34.26 MH/s
[2018-02-27 22:04:14] GPU #5: Gigabyte GTX 1080 Ti, 34.18 MH/s
[2018-02-27 22:04:14] GPU #1: MSI GTX 1080 Ti, 34.08 MH/s
[2018-02-27 22:04:14] GPU #3: MSI GTX 1080 Ti, 33.91 MH/s
[2018-02-27 22:04:14] GPU #3: 1958 MHz 130.13 kH/W 261W 59C FAN 0%
[2018-02-27 22:04:14] GPU #0: MSI GTX 1080 Ti, 33.83 MH/s
[2018-02-27 22:04:14] GPU #4: Gigabyte GTX 1080 Ti, 32.90 MH/s
[2018-02-27 22:04:15] GPU #6: MSI GTX 1080, 33.43 MH/s
[2018-02-27 22:04:45] phi block 192427, diff 13509.294
Cuda error in func 'skein512_cpu_setBlock_80' at line 1095 : the launch timed out and was terminated.
[2018-02-27 22:04:45] GPU #6: OS call failed or operation not supported on this OS
-- 1:ccminer -- time-stamp -- Feb/27/18 22:06:46 --
Приходится вручную рестартовать.
Помогите, в чем причина?
Can you add HSR to the webgui ccminer supports it but can’t setup a wallet for it.
How to add this fork?
Could you consider adding Ennemy - ccminer fork please?
Located at: https://github.com/Enemy-Mine/ccminer/releases/tag/v1.03-RVN
[quote=“redlum;1186”]How to add this fork?
https://github.com/nemosminer/ccminer-hcash/releases[/quote]
+1
HSR Miner is Amazing!
Please Add, tried compiling myself, but failed. It doesn’t support compute_20 in cuda 9, stuck on that step.
Thanks!
I have another problem! I need to start the ccminer miner with fork sp mod. In wallet pick a ccminer, fork - sp mod, algo - phi. As a result, the miner writes in the log “ccminer exited waiting to cooldown a bit”.
How do I start this fork?
I second ennemy fork for RVN; https://files.fm/u/thtcdp63#_ could not find the github page anymore
sorry for the double post, can we have this fork included too since it has x16r as well? https://github.com/MSFTserver/ccminer
Is anybody have sources of Enemy-Mine ccminer?"!!!
do anyone know how to add this fork: palgin mod?
Please add Ennemy - ccminer fork? :slight_smile:
Sorry i dont know how to start a new Thread so here my Problem:
I want to set Intensity in ccminer klausT Fork to 15 but always it takes the default settings
What is wrong?
I want to set Intensity>>
you should use :
“intensity” : “17”
X16R / Ravencoin miner, same hashrates as enemyminer, 20% higher than default 2.2.5 ccminer
+1 for nevermore request. Been mining RVN lately and 20% over the “rvn” fork version currently in hiveos right now sounds good.
[quote=“rungo;1823”]https://github.com/brian112358/nevermore-miner/releases
[/quote]
added to wishlist
http://forum.hiveos.farm/discussion/435/request-miners-for-adding-to-hiveos-maynery-dlya-dobavleniya-v-hiveos#latest
