Do you make something bro, i have also x6 EVGA 3060, i cant swap all in eth…
I haven’t been able to get the 0% fan hack to work. It looks like some people in the thread had some luck.
I settled on using lolminer with the 3/4 speed unlocker for now.
I also run on lol miner now with 37. I do it one time with 0% fan and its works maybe 10 mins with 52 mh/s on t-rex from ergo change, but this didint work good. Im waiting for lol miner to unlock full
Hello, bro. Well done. Can you make another video on youtube, with
new complete tutorial, thanks for all help. We are thankful from your welldone job.
I also put it on Ergo, im mining with 121.5 mh/s per card or total 730mh/s with x6 3060 EVGA
I have fan 85%/core -200/mem 2200/pl 115. I dont lose nothing to wait to glitch with this oc, when its done i will change on gminer with that
–safe_dag 2
-k 4
-i 96 settings, and i will try to put all to mine ETH, we will see. Nothing to lose, we can only get more.
Also work with N460.39 driver
We will see.
goes well with gminer? I use it with nbminer and I have some rejected. where does that config go in gminer did I upload some captures
With these settings I doubt you will ever achieve the glitch. Personally I need to be in the 3000+ range of memory OC in order to make the glitch happen. Currently, I am at these settings, running for days with the occasional miner restart once or twice during the day (usually runs for 10-14 hours before miner restarts):
In order to achieve this stability I use Gminer 2.55 and added these config settings (intensity is at 95% atm):
Hope this helps!
hi bro , what meaning using Trex for ETH mining ?
go to Flight sheet - there you select which miner you want to use for the machine that you are setting up
Gmine, Trex are one of the option for miners…
Anyone try this on the new 3060 lhr cards? Specifically ones that can’t install the 470.05 driver?
What is the procedure for a larger number of cards? If I try it with one, it works, but it doesn’t work for others.
