would you like the factory firmware back? I only put this firmware to see if it would correct the problem.
Seems to be a windows related error, possibly firewall/antivirus. Do you have any other devices to try running asic hub from?
You can also try the steps from this link Ports are not available: bind: An attempt was made to access a socket in a way forbidden by its access permissions. · Issue #12530 · docker/for-win · GitHub
what setting do I have to change
well, Can not get to work, I guess I have to find new monitor OS. thanks for the help.
