Can you post a screenshot of your ASICS local dashbaord (accessible via ip address) miner configuration page?
Are the parsefloat errors only on asic hub, or are they also in the miner log on the device?
only in Asic hub and Hive OS.
Just noticed you’re running aftermarket firmware. Does it have the same error with stock fw?
yes it does.
Hive shell isn’t a supported command on any miner that’s not running hiveon firmware
still have the unreachable and syntax error any Ideas what to do?
Can you send me a link to the worker url? I can have some people take a look.
did you get the message?
Yes I did, I forwarded the info to some of the asic hub devs, will let you know what I hear back then
I real want to use HiveOS for tracking miners
Devs are working on a fix now.
ok, I have put two back on line I do not want to pay if not working correctly there is one D3 and Z9 mini on line now. and showing the errors.
Did you only receive those messages on the d3s? Or also on the other miners?
all antminer D3: STRCONV.PARSEFLOAT: PARSING " 0.0000": INVALID SYNTAX and device is unreachable (Get “http://xxx.0.0.xxx/cgi-bin/get_miner_conf.cgi”: read tcp xxx.0.0.xxxx:50357->xx.0.0.xxxx:80: wsarecv: An attempt was made to access a socket in a way forbidden by its access permissions. and on the Z9 mini: device is unreachable (Get “http://xxx.0.0.xxx/cgi-bin/get_miner_conf.cgi”: read tcp xxx.0.0.xxxx:50357->xx.0.0.xxxx:80: wsarecv: An attempt was made to access a socket in a way forbidden by its access permissions I have one of each on line.
A new test build is being compiled now, I’ll send the link when it’s ready for you to test
can you try this version of asic hub? let me know if it fixes the error Index of /hub/testing/797889947/
Great, waiting
Link is above to the test build
same error messages D3: STRCONV.PARSEFLOAT: PARSING " 0.0000": INVALID SYNTAX and device is unreachable (Get “http://xxx.0.0.xxx/cgi-bin/get_miner_conf.cgi”: read tcp xxx.0.0.xxxx:50357->xx.0.0.xxxx:80: wsarecv: An attempt was made to access a socket in a way forbidden by its access permissions. and on the Z9 mini: device is unreachable (Get “http://xxx.0.0.xxx/cgi-bin/get_miner_conf.cgi”: read tcp xxx.0.0.xxxx:50357->xx.0.0.xxxx:80: wsarecv: An attempt was made to access a socket in a way forbidden by its access permissions ,
but had this in hub log
