I looked at the extra profitability of dual mining and you only make an extra 0.79$ a month or 9.64$ a year
and that is if you have not loss in the ETH hashrate.
To be honest i am not really interested in dual mining but i will share my cooling solution with you.
Hope that helps.
Also i tried chaning the straps (memory timings) but i have not seen any change
Thank You for Your information. I think TON is a coin which doesnt make loss ETH hashrate but needs more power.
Here are the results
I am drawing an extra 5w when mining TON and ETH for a total of 125w vs 120w on ETH only
I also lost 1 mh/s because i cant do dual mining on team red miner, i dont know why if you have a solution please let me know.
From what i can see, if i am able to keep the same hashrate (24mh/s) on ETH then dual mining is more profitable but i am not able to because i cant dual mine on team red miner.
How did you get the cards to read?
what do you mean buy read, if you mean mine then what i did is put them in a Windows machine and installed the latest amd drivers that this card supports. Then i put it back on to my hiveos machine for better performance.
yoyo2001 I have try everything but still can not get AMD FirePro s7150 to mine. PCI-E is set 1, load cards in Windows 10 with news drive then in HiveOs, install AMD Pro Driver.
Here what I have.
Check the BIOS settings - try to change PCIE link speed from GEN3 to GEN2
Hi, PCIE is GEN2 link speed
RUN
sed -i ‘s/ pci=noaer / pci=noaer,nocrs /g’ /etc/default/grub && update-grub
