Hello everyone y have a 6 RX 6800XT that I built 10 days ago. First 5-6 days it was working good but now im getting this issue and i cant start mining. Looks like it doesnt read the cards well but i have tried reinstalling, without OC applied, with a lot of algos and already checked them all. If i only connect 2 o 3 it works well. Did anybody have this issue?
try another mainboard
Looks like you just upgraded to the latest code.
Have you tried to backdown or load the latest “stable” code?
Yes I already tried with latest stable and a previous one which is 0.6-206 but still the same
and latest beta?
riser problem
0.6-207.211010
Hi
Try another pool for AMD Teamredminer is best. I had same issue with 12x 2060Super MSI after Hiveos upgrade simply I switched from T-Rex to Gminer and everything got back to normal. Maybe same thing could apply in your case
I had it working ok the last 30 hours but I turned it off and now i cant make it work again. I dont think its a risers problem because it was mining and i checked one by one all the gpus
if you oc on running system, reboot and get no start, you did too much.
reset all oc and start new … then try other settings
This is using GMiner and the F-state script posted above. You’ll also need HiveOS v0-605 or later.
My oc works great an stable if i go higher with the ram it crash. And it runs with the lolMiner
SAMPLE PAYED SETTING FOR CUSTOMER
enjoy please :slight_smile:
So i decreased the power draw a little more while keeping hashrate same on TeamRedMiner
Hi there , which is best driver version for now ? I have 6800xt which is doing 62.5Mh/s @113W
Drivers version - A 20.40 (5.11.0701)
Im using TRM , is there any better than it ?
Tnx for advice !
Great settings. Does it run stable ? What miner and version are you using ?
Can you post your Settings for your 6800 XT please?
Yes, it has been working stable for 2 months. Latest versions of Teamredminer or gminer
