Hi Keykhosro ! Awesome hash rate and power consumption, what miner and version are you using ?
wow, your GPU is so good. I have 2 GPU 6800XT,same hashrate, but power from 134 - 140w
Well done I think you are going to be happy with those XFX cards. Only have (1) flaky one in my stack. Wish I bought more.
Hi! Can you share your setting in now? I config like you but my GPU but now it not stable!
Hi nocive, OC settings looks great. May I ask what version of Hive are you using, I’m not seeing the core state in my configuration
0.6-210@210925
Hi LuckyMan, May i know what’s the miner software do u using? Gminer? Teamredminer?
Hello. Teamred.
Hey I’m here for you!
SOC VVDMAX is based on the luck of chip, i got other RX 6800 XT that needs 980
Without using beta you got arround 148W with beta version of hiveOS you got 122W (reported in hiveOS didnt check out of the wall)
also my reported hashrate goes from 61 to 62,7
And I think you can get better if you try more clocks
teamredminer v.0.8.5
Thanks for reply, i will try to use your setting. it is great. especially the power.
how do you set your fan auto run?
For those here looking for settings on the 6800 XT, here’s the sweet spot for me (best between high hash rate, low power draw, and solid stability).
Took me a minute to get to these settings; looks like there are pretty wildly mixed results from different people’s OC settings on the 6800 XT; I can’t get this below 1325 memory voltage without the card promptly dropping to around 60watts and only hashing like 17MH/s…
Would love to see if anyone can crack 64MH/s (or even 63.5) at 100W or lower.
*edit to add: this is rockin’ exactly 100w (no power limiter). My 6700 XT in the same rig is cruisin’ at 90w and 46.8MH/s.
i have 63,66 at 118W but not everything is like that.
