Do you think my temperature high?
不會啊~
很低了
By the way, what is the optimal temperature for GPU and Mem in 6800xt?
I have the same issue. How to fix it ?
Better than me. What is your clock setting ?
What cards are these and which miner are you using?
Thanks bro
What is your miner?
What are your cards? Can you get a picture that includes the card models?
I have a strange issue when my rx6800 spikes from a stable 61.44 mhs to 66.xx then my entire rig will lower its mhs for a minute or so by say 25% mhs then revert to normal. All the other cards are 5700xt. Any ideas? I run 1350/700 and 1065 mem. Stable at 1070 but i recently lowered it to see if it stops the strange spike and drop anomaly.
All 6800 owners.
Go to that post and do it.
Happy mining
Do you want stable maximun hasrates for your cards? do it
The 6800 spikes up in hashrate every now and then. After which, DAG will be recreated. It’s likely that your other cards are being affected (maybe autotuning?).
Anyways, check out the link posted above. Seems like a good script to run.
It certainly has stabilized the majority of my fickle 6800 series GPUs. Have not seen a downside over the last week. Only upside so far.
I do have at least 1 Sapphire 6800 which still resists everything I have tossed at it…letting it run at 57.5-59 until I have time to pull it from the rig and toy with it or just run it in Windows.
