Hello Ajzd can I know if it’s Sapphire NITRO+ Radeon RX 6700 XT
11306-01-20G
yes, it is a sapphire nitro +
Thank you so much
Try 825 socvddmax
I love you
Working
6700 xt micron ergo ayarı olan var mı ?
Does anyone have a 6700 xt micron ergo adjustment ?
More than a year later, I’m having the same problem as you did. I can’t change VDD, mine keeps locked at 868mV. Did you ever find a solution for this?
Hi everybody !
I’ve got 2x RX6700XT… I could use them to build a PC Gamer Thanks to multi-GPU technology (CrossFire) … BUT what could be the performance in gaming ???
If you could clear my questionning
Thanks alot !!!
hi my friend
I need help I have trouble with gpu 5 every time it put me dead every 5 minutes
I don’t know how to be stable with rvn coin
I need help. I try configure OC for Ghostrider in my RADEON 6700 XT XFX 12GB
your memory clock is too high, try 1073
Also raise your memory voltage. Start around 1280 and drop it if it is stable
Not sure about your core and mem controller voltages, seem low.
Your hr seems low. The 6700 should do around 22-26 on kawpow, unless you are going for low power use
thought gr was a cpu algo?
what memory is used on your video cards?
