6700xt General Discussion
There goes 1st (Eagle), vs 2nd (rgb/gaming).
Note, both have xxx-xxxxx-xxx BIOS :frowning:
Flashing newer seem like logical another step.
Lets go to Google :slight_smile: (any link to your dump is welcomed).
yes, they are supposed to add your model to the hiveos. That’s why you see XXXXXXXXX
Ehm … just to make sure, what you mean by that? I saw xxx-xxxxx-xxx at another OS too, and it was directly read from BIOS (like BIOS PN).
What you mean by “ad model to HiveOS”?
Btw, … yatta :slight_smile:
With 6700XT Eagle, and flash “113-D51221-R67XTE”
dl link: VGA Bios Collection: Gigabyte RX 6700 XT 12 GB | TechPowerUp
With Core 1300, mem 1075 ( !! NOT 1076 !! ) Im getting 46-47.6M with Phoenix.
@LazyPanda try this too (and make backup of course).
Btw, do you have any BIOS with PN (and not xxx) for that Gaming edition too?
More or less to see PN or BIOS dump is enought.
Logs if someone is interested (for Eagle):
=== Flashing card 0 ===
AMDVBFLASH version 4.71, Copyright (c) 2020 Advanced Micro Devices, Inc.
Old SSID: 2331
New SSID: 2331
Old P/N: xxx-xxx-xxx
New P/N: 113-D51221-R67XTE
Old DeviceID: 73DF
New DeviceID: 73DF
Old Product Name: GV-R67XTEAGLE-12GD/F1/0B95
New Product Name: GV-R67XTEAGLE-12GD/F2/0B95
Old BIOS Version: 020.002.000.019.000000
New BIOS Version: 020.002.000.019.000000
Flash type: W25Q80
Burst size is 256
100000/100000h bytes programmed
100000/100000h bytes verified
Restart System To Complete VBIOS Update.
=== GPU 0, 0a:00.0 Radeon RX 6700/6700 XT 12272 MB ===
  Bios: 113-D51221-R67XTE
  Core: 1300 MHz 843mV, Mem: 1074 MHz
  PerfCtrl: manual, Load: 99%, MemLoad: 44%, Power: 123.0 W, Cap: 186 W
  Core: 49°C, HotSpot: 53°C, Mem: 74°C, Fan: 73%, RPM: 2486
  Core state: 1, clocks: 500 1300*
  Mem  state: 3, clocks: 96 456 675 1074*
  SOC  state: 1, clocks: 480 1066* 1200
  DCEF state: 1, clocks: 417 960* 1200
  F    state: 1, clocks: 500 1941*
  PCIE Link speed:n/a, PCIE Link width:n/a
  Memory total: 12272.00 MB, used: 4393.31 MB, free: 7878.69 MB, type: Samsung GDDR6
can anyone hep me with my rx6700 hashrate lower than my 4gb cards
do you guys successfully undervolt your rx 6700xt? I’m able to run my 6700xt on windows at 650mv and the temp is around 50C or lower. on hiveos, I set the vcore to 650mv with the same clock at 1100mhz and the same fan rpm, but the temp is higher at around 55C. I checked with amd-info and found that the vcore was detected as 878mv. is there a problem with undervolting on rx 6700xt?
You Did not do an entire new flash-drive/SSD disk it seems :slight_smile:
You need to do a specific tune for this card… right now it’s overclocks are from the Radeon 570 cards, and THAT is no good :slight_smile:
For overclocks, please just look in this thread a little above, there are plenty examples of good tunes.
Yeah, I also see errors when trying to use different Voltage settings in HiveOS compared to Windows/AMD Overclocks app. My best guess is that there are still tweaks to come for this card in this specific regard.
Are you still using this oc config without issues?
Yes. Will change it later to get the extra 3mhs as long as I can keep cool temps. Currenntly not close to the rig so this is really good.
That reference runs super hot but, can’t beat the price :slight_smile:
Please post it here if you get better results, I’m trying to change the numbers a little bit to see if i can get more mh/s with less power, actually getting 43.60 with 91wats with your config, was getting 47.00 with 120watts, also I have another 6700 and the config looks different and can’t get it work with the same specs i dont know why. But thanks so much for post your config
I already tried beta and stable updated. Both gave me the same “Unknown GPU”. (RX 6700 RT ASUS STRIX)
My only option is to wait for a newer Hive version? :thinking:
You DID IT!) thx a lot!) Really it works.
GIGABYTE Radeon RX 6700 XT 12288Mb EAGLE (GV-R67XTEAGLE-12GD)
Problem with low hash rate is solved! Thx to you @Gecon ! :sunglasses:
whats wrong? I have the latest version of HiveOs but I still can’t mine.
I am using the latest beta version too and I am getting this error. model xfx
I’ve done everything, but I haven’t done it yet!
hiveos-0.6-200-beta@210303, this is the version I downloaded from the HIVEOS website
No AMD GPUs found as /sys/class/drm/card*/device/pp_table
this error message is reported when I give the command to research AMD
  • amd-info
I downloaded normal gpu (not beta) zip from the Hiveos site and did a clean installation from the beginning and now I can dig with 43 mh, this time I did not get a gddr error
I managed it too, did a new boot and it worked but it is crashing
