3080 OC Settings + Underperforming Cards
for anyone that still need OC settings this are mine. i get 101MH at around 220w on the 3080
What kind of PSU and MB and Miner u used
Hola, las 3070 y 3080 son sin LHR para alcanzar esos valores de MHs?
hi ihave same problem , above 1300 crash and from 900 to 1350 stable
i try to flash bios and flashed, but same results, i dont have any thermal issues at all, and my psu is EVGA 1300Watt
If you found a solution , please inform us here , thank you
have you tried to set up the power limit to see if you get any improvement?
yes , if your mean is change PL in custom ranges , yes i did it, but no improvement. i think its hardware, and bad silicon lottery for mining
Watercooled Aourus 3080 105mhs
Is this card non lhr ?
Are these 3080 non lhr ?
Donde compraste las almohadillas para la 3080 tenes las medidas que lleva. Gracias
all of them are NON LHR
try
core 1070
memory 2400
pl 230-235 (depends if u set 230 and card pulls 229, you can set 235)
around 100 mh
Wow, so many people here can do 100+
My shit MSI Gaming Trio X can only do 91-93…
Hi All I have issue with 3080 MSI cards.
They are underpreforming and I do not have idea how to corect it.
All other runs fine.
Any ideas?
driver - 510.60.02
nbminer latest ver
core clock 1060-1100
mem - 2300-2350
i am getting 99.5mh and good temps
Good luck
MSI card is pissedshit.
need update bios to better vendor example EVGA bios
