3070 LHR Mining Raven and Ergo Settings
How did you get 160mh I have the same card, but from a company palit and it did not exceed 120mh
if you are talking about ERGO which i can tell you, you need more clock speed, Ergo kinda likes more clock speed than memory.
Yes Can you write your own settings
i am sorry i dont mine ERGO , but you can use your ETH OC and just put more to core clock and see how it goes. Maybe you can reduce a bit the memory clock since its not so important, but its a matter of testing. And test by small steps.
I used a lot of settings but it doesn’t exceed 120 mh
someone already tried mining eth and ergo/rvn at the same time? for ex: gminer --intensity 70/30
Which drivers you are using that you get 160mhs from 3070lhr ? I see people can’t do more that 120mhs. Today i connect 2 x 3070 LHR Gainward and i want to get also 160 mhs :slight_smile:
On ERGO i have between 88-106mhs, why so small ?
Ergo is nearly identical to Eth, except you need more power, which means absolute core doesn’t work well.
it’s NOT core intensive at all.
-502
2600 mem.
Between 120 and 135 pl depending what efficiency your looking for.
That’s non LHR 3070s
I can’t have stable ergo i’m trying diffrent configuration, i have 3070 lhr how to set it?
Watch YouTube videos
My 3070 -
GeForce RTX 3070 7982 MB Ā· MSI
30.35 Hash Rate
1100
2600
160
is it safe to have the power limit at 160?
Looks like you have an LHR GPU. Your only at 30MH.
This is for RVN not ETH
I have this for my 3070 LHR …
Can i have better ?
SMI Commands: How to mine ERGO with a RTX 3070 LHR (~135 MH/s ~89 watts) | The fight continues - YouTube
LHR Unlock: youtube.com/watch?v=O3A-Ck0nsFo
Try adding ā€œlhr-autotune-modeā€: ā€œfullā€ in your flight sheet for t-rex miner.
Edit: ā€œlhr-tuneā€: ā€œ91ā€ may work better. Mine seems to do best at 92.5.
