3070 LHR Mining Raven and Ergo Settings
Well, it’s stable and under temp; it’s an ftw3 lhr so I’d say it’s a healthy choice for this card. I’ve been mining since 2013 and have yet to kill or brick a gpu (i’ve had the p106’s since launch and mined on 390’s before that), BUT there’s a first time for everything.
Under what temp?
110c gddr6 max; I (and probably most miners) aim for 60c under load.
Your at 60c at 3325?..
No way
I’m under at 54c and 57c
Memory temp?. Lol i dont buy it
Show me
Core temp. As you know, there’s no way to see memory temp on hiveos (maybe i’ll get cracking on coding a hiveos memory temp feature). backplate spot temp with digital thermoter has it at 38c, gpuz on my test bench had it at +/- 3* of core under max load (3000 on windows) so I’m taking that as core as my reading.
Lol this is exactly why i asked. yes, im very aware that u need to benchark in windows first.
Your core temp has no bearing on memory temp.
You could have a 30-40 degree difference between them. Never assume.
Your cooking ur memory, your over max.
Back plate temp isn’t at the memory junction
I have 3 RTX 3070 LHR, and been mining RVN for more than a week now
stable at 30.8 mh/s @145W
@ andrewholland This is stable for ravencoin? Did you try ERG with this card?
Wembley,
I have since made small modification as was getting some invalid shares:
17 July 2021
Linux HiveOS:
Driver: 465.31
Hashrate 39.6 MH/s //// Core: 110 // Mem: 2100 // PL: 250w // Fan: 80%
No I have not with ERG, my objective is RVN till Jan 2022 till the halving…
What are your overclocks.
I may try on my non Lhr 3070s today to experiment.
i tried your oc setting on my 3070 ti, but kept dropping to 30 mh/s after a few minutes
do you use the dummy hdmi plug?
Thanks andrewholland for he quick response. Your ZOTAC - RTX 3070ti AMP Holo is LHR or non LHR?
1100 / 2600 / 145
with non LHR, should be more or less the same
i dont think kawpow is limited on my 3070 LHR
all 3070 ti and 3080 ti gpu cards are LHR
LHR as new gen GPU are now… ETH was reduced 50%
I do not use the dummy plug, I have noticed from the forum, YT and other sources that these Zotac 3070Ti AMP Holo seems to over perform…
what miner do you use for mining RVN?
