Hi, which the original firmware of Asus TUF?
Is it a 3 fan model?
I have one Asus TUF 3fan model:
GeForce GTX 1660 SUPER 5944 MB · ASUS
Hynix GDDR6 · 90.16.4F.00.73 · PL 70 W, 125 W, 150 W
Yes, please share us update for single fan model.
Thanks.
I can confirm, Palit BIOS worked on PNY SL8 single fan model. However, notice the PL display is 0,0,0 for this card, other cards are 70, 125, 150, but mining works
Fantastic! Thank you for update.
I’ll try to see if I can update my MSI single fan model later…
The 4 cards I flashed with Palit Bios all worked separately. Now I am going to put them together and see if they are stable. I am lowering the memory speed now than I posted earlier, b/c the earlier numbers are not stable. I hope this helps. Thanks.
I tried to flash my Asus TUF 3 and it done fine!!!
Thanks, you encouraged me to flash my card, just to see what happens.
And it worked at a first moment!!!
My Asus TUF3 card is mining at +35MH/s, let’s see it will run stable.
我使用了轻松矿工刷入了同德的bios,可以用,刷完之后算力34.8Mh/s
我的卡是七彩虹战斧1660s。采用gminer挖矿,刚开始使用核心1200/显存1100跑了2小时内核重启,所以改成核心1050/显存1000跑下来10个小时,目前稳定
运行14小时后内核重启,我把显存频率下调到950,继续测试看看,算力跌到34.55Mh/s
Thanks a lot bro… Pls keep us posted with further results…
Did anyone flash in HiveOS ?
I tried, but failed. Even if I choose “force flashing ignoring security checking”, rig will reboot and end up without flashing
Lower the PL on the PNY cards to 70w. Hashrate seems to stay. But I am not sure if the powr reading on that card is correct
Cannot lower PL too much on Asus/ MSI card before hashrate to drop.
Can anyone confirm if you can flash these cards with the bios file straight from within HiveOS? Thanks
what’s the problem with your rtx3060? 117.9Mh/s hashrate??
Ergo?
I can’t flash in hiveos too,
Flash it in windows. I will get error too in hiveos.
Eu tentei pelo windows e deu erro, nvflash no adapter found…
