Good Job Buddy.
I did it too about an hour ago and It’s ok, FXXK more hashrates!
just if I just find a way to be stable I may flash the bios again.
Good Luck bro
Good Job Buddy.
Good Luck bro
If you rig crashes, lower memory clock by 50, it will stable eventually. at lease some of your cards will be stable. The process may take some time, but you will gain 10% in hashrate. Of course, not everyone can do it.
i have gaming x 1660 super with samsung memory getting 32.3 mhs on stock bios, can i mod palit bios to my 1660 super samsung memory card?
I did it on Windows 10
-6 is a parameter you need to declare in the nvflash command;
nvflash --index = 0 -6 rom_name.rom
My TUF 3 is super stable, mining for almost 3 months and no crashes.
what is the oc for inno3d twin x2??
i realised after 1 month ago
after flashed bios , yes we gain more hashrate on hiveos dashboard and reported hashrate (hiveon)
but the mean and real hashrate actually is nothing changed LOL , and i getting error every 3~4days
now im considering should i flash back my original bios ><
It’s up to you what you want - more hashrate (the system crashes constantly) - or a little less hashrate and you have no problems. I personally chose not to have problems.
Everything works on the ASUS Strix 1660 Super, BIOS from the Palit. Cards are unstable all the time crashes every ~1h without error in log. I did it and did not help:
yea the flash is unstable. Miner keeps restarting every 4 hours even with low overclocks.
It’s crashing because of the memclock setting and not the core clock. Lower the memclock in increments of 50 or 100 until the fan stops turning into 0%.
are nbminer stable than trex?
trex keep crash after few hour =(
My friend, is my ASUS DUAL 1660S suitable for palit bios? Thank you~
are you still running with parameters 1230-2500, is it still stable
I have 1 PNY 1660 super, with PALIT BIOS it crashes sometimes from 1h to 24h, it crashes my whole rig, so im gona try to revert BIOS.
Been mining on my 1660s since March 2021. A healthy and consistent problem free 31.6mh/s. Now that she’s paid herself off, ready to see if I can squeeze some more juice out of those cards.
Palit bios mod is a nice little bump if it stays stable. Would net me an extra $2 a day out of this rig.
Thanks @Iveq
what benefits for more clocks?
more stable or more hashrate?
I think for me, it is more hashrate, a little more. You have to test for yourself.
my colorful 1660s hinyx memory not stable using t-rex, freez after 1hour
