It's a lightweight application running on the stock (or custom firmware of your choice) ASIC firmware.
Supported ASICs:
Actual list can be always found on GitHub.
All the instructions on Hiveon OS Client installation can be found here.
It's a custom firmware that replaces the stock one. Supports only selected models: Antminer S17, S17+, S17E, S17 Pro, S9, S9i, S9j, S10, L3+, L3++, T9+, T17, T17+, T17E.
Hiveon Firmware for other ASIC models are coming soon, so stay tuned!
Hiveon ASIC Firmware features:
All the instructions on firmware installation can be found here.
Hiveon OS Client and Hiveon ASIC Firmware are not the same products.
| Model / Feature | See miner in Hiveon OS | Control wallets & pools | Restart miner | Reboot miner | Anti-virus (Hiveon FW only) | Over clocking (Hiveon FW only) | Under volting (Hiveon FW only) | Voltage adjustment (Hiveon FW only) | Auto-tuning (Hiveon FW only) |
| Antminer | |||||||||
| A3 | * | * | * | * | |||||
| B3 | * | * | * | * | |||||
| D3, D3 (Blissz) | * | * | * | * | |||||
| DR3 | * | * | * | * | |||||
| E3 | * | * | * | * | |||||
| L3+, L3++ | * | * | * | * | * | * | * | * | * |
| S7 | * | * | * | * | |||||
| S9, S9i, S9j | * | * | * | * | * | * | * | * | * |
| S9k, S9SE, S9-Hydro | * | * | * | * | soon | soon | soon | soon | soon |
| S10 | * | * | * | * | * | * | * | * | * |
| S11 | * | * | * | * | |||||
| S15 | * | * | * | * | |||||
| S17, S17+, S17E, S17 Pro | * | * | * | * | * | * | * | * | * |
| T9 | * | * | * | * | |||||
| T9+ | * | * | * | * | * | * | * | * | * |
| T15 | * | * | * | * | |||||
| T17, T17+, T17E | * | * | * | * | * | * | * | * | * |
| X3 | * | * | * | * | |||||
| Z9, Z9-Mini | * | * | * | * | |||||
| Z11 | * | * | * | * | |||||
| Innosilicon | |||||||||
| A5/A8 (need test) | * | * | * | * | |||||
| A9 ZMaster | * | * | * | * | |||||
| D9 DecredMaster | * | * | * | * | |||||
| S11 SiaMaster | * | * | * | * | |||||
| T3 BTCMiner | * | * | * | * | |||||
| T3H+, T3+, T2Th+, T2Thf+, T2Thl+, T2Th, T2Tz-30T, T2Thm, T2Thf, T2T+ (32T), T2Ts-26T, T2Ti-25T, T2T-24T | * | * | * | * | |||||
| Todek | |||||||||
| Toddminer C1, C1 PRO | * | * | * | * | |||||
| HashAltCoin | |||||||||
| Blackminer F1, F1+, F1-MINI | * | * | * | * | |||||
| Blackminer F1-Ultra, F1-MINI+ | * | * | * | * | |||||
| Zig | |||||||||
| Z1, Z1+ | * | * | * | * |
For any information you may need about ASICs, please check our forum, Github or our Knowledge Base.
