Hello everyone.
I seem to have some problems on my Zotac Trinity OC - rtx 3080 gpu’s .
The problem is that I can’t get the fans higher than 85 - 86 - 87%.
At the beginning they worked at the speeds I needed (95%) and now I think maybe since the updates it is not working anymore above the speeds mentioned. I tried some downgrades of versions for hive , even on the miner but no success. I simply can’t get them to work up to the maximum that it should.
Does anyone have the same problem as I do? Is there a fix for this ?
P.S. : In windows the fans can be ramped up to 100%
Thank you in advance for reading the topic!
Screenshot:
