Zotac RTX3090 ArcticStorm Overclocking Setting
Hello guys, does anyone know how to set this card? I set core 1100, mem 2200, PL 330, but my active PL is only about 274. I’d already changed the thermal pad, but it still not help.
I’ve just bought the same cards and have the same problem. Core 100 and mem 2250 are the sweet spot for config, but like you, they won’t pull more than 275 — 280w.
I believe the cards are thermal throttling, even though my max gpu core temp is only registering low 40-43deg C in Hive.
TKS ,and how’s your Hashrate?
With 6 cards plumbed in series but only the first 3 currently running, 117Mh on the 1st and 3rd cards and card 2 is only 108Mh.
Hi
I have the same problem. Did You get any help?
