Zotac RTX 3060 Thermal Pads
Hi.
My rig is made of 6 Zotacs: 3 x Twin Edge, 2 x Twin Edge OC and 1 x AMP White Edition…
I want to change the thermal pads with Thermalright ODYSSEY ones, but I can’t find out the thickness I need. I also intend to put thermal pads for the backplate…
And, also, how many packs do I need for each card to have enough?
Is it the same amount as 3600Ti and the same thickness? 1.5 and 2.0 for the front and 3mm for the backplate?
You shouldn’t need to change thermal pads on gddr6 cards, the memory doesn’t run that hot. But if you insist, use some digital calipers and measure the current pads
