Zotac RTX 3060 - Noctua Fans replacement
Hi.
Summer is coming and I’m planning to replace the original fans on my video cards with Noctua fans. Which size should I go for, the 80mm or 92mm? As the original fans are 88mm.
I’m thinking to choose the 92mm version from Noctua, NF-A9 PWM, but without using the PWM feature of course. And any advice is welcomed.
Noctua NF-A9 Specs
My second problem is that the stock fans are rated at 0.46A, while Noctua is max at 0.1A.
