Zotac Mini GTX 1080 Ti - Thermal pad simension and thickness
I will be replacing thermal pads on my Zotac Mini GTX 1080 Ti. I already searched the internet and failed to find something that applies to that specific card and model.
Anybody who did it before, I am looking for dimensions and thickness for the pads.
This is a second hand used card and weather change to summer makes it probably thermal throttle (this is what what I am told). I will take my chance with paste and thermal pad replacing.
Any help is appreciated.
Thanks & Regards,
Ertan
Why do you need to ask people, just take off the cooler and gauge the stock pads yourself, all you need is a ruler!
Ruler measurements are not that accurate. If somebody already tried and realized that a certain measurement is not the best, that information helps a lot.
