Hello there,
I need help for my mining rig. I use 3x zotac 3060 ti LHR using nbminer with 1400 core, 1750 memory and 150 PL settings.
It will mine normally for 10 minutes, 30 minutes, 1 hour, 2 hour (different everytime) and then suddenly one of the GPU will display no hashrate with an error message “driver error, no temp”, the load average will go up and then other GPU will follow until all won’t mine at all.
I have tried changing my riser (all three of them) but the problem still persist, i have tried using other miner, different overclock settings but still no luck
Has anyone met similar problem as mine and maybe have a solution? Thanks for your time.
