I recently did an upgrade to hiveos and since then my cpu has been running hot forcing me to shut it down and unable to use hiveos. I’m a noob at this so if anyone could assist that would awesome
Looks like your fan is bit running
Use xmrig-new instead xmrig
You’re losing too much hashes on old version
I’m still trying to figure out how to switch it. I’ll give it a try.
The issue is moreso the temperatures I’m getting. It’s like my water cooler doesn’t want to start anymore since the last upgrade but works properly when I mine xmr on my windows. I tried downgrading and it did not solve the problem either.
Can you solved it?
I was wondering what are you going to do about the fact that Monero has been removed from all exchanges, since this coin was banned in almost all countries?
