XFX RX6700 XT QICK 319 Mining Settings
I am struggling with trying to get my card stabilized. Anyone have any suggestions on the overclock settings. I realize that silicon lottery will be playing a part in this. My intention is to get it running and then play with it. Error message received is TeamRed Miner GPU2 detected Dead
Running
TeamRed Miner
Hive OS 06.-213@220205
Asus AB350 Pro4
Any help suggestions will be appreciated.
Kent
Assuming you are running 5.10 #83 Kernel.
Back off from 1075 memory a bit if you are getting issues with these.
Thank you for the advise. Will move in that direction. And yes I am running 5.10.0 Hive OS #83 Kernal
