XFX Amd Radeon RX 6700 xt 12 gb can run on one power cable?
So my question is that i ordered a rx 6700 xt and i have some limitations in cable section, so can i run the video card from only one 8 pin power cable or should i put the other one in. Because i saw that it should get around 80-90w of power usage so i assume that i can use only one cable.
What is your opinion?
Thanks for reading my topic!
Best regards Otto!
