Greetings. I have a rig that uses 8 x 5700 XT cards running on a HiveOS USB. (I have to use the Beta version of HiveOS for these cards for the software to recognize and provide better descriptions for the graphics cards). Using the online interface, I was able to extract the original bios from each of the graphics cards and I saved each original bios image into its own file name.
I then loaded each Bios, one at a time, into RBE and modified the VRAM timings. After modification, I saved each bios image to its own filename reflecting that I had modified it.
I then uploaded the modified files back to HiveOS and then applied each modified bios to the same card that I obtained the original bios from as I am not sure of any differences of the Bios between the cards, e.g., some cards use Samsung Memory while others use Micron memory.
Card #0: Radeon RX 5700 XT 8176 MB · XFX Micron GDDR6 113-230LNAVIXT612_8GD6_MS_W8
Card #1: Radeon RX 5700 XT 8176 MB · XFX Samsung GDDR6 113-230LNAVIXT612_8GD6_MS_W8
Card #2: Radeon RX 5700 XT 8176 MB · XFX Samsung GDDR6 113-230LNAVIXT612_8GD6_MS_W8
Card #3: Radeon RX 5700 XT 8176 MB · XFX Samsung GDDR6 113-180W2NAVI10XT8GD6_MS_191122_W8
Card #4: Radeon RX 5700 XT 8176 MB · XFX Samsung GDDR6 113-180W2NAVI10XT8GD6_MS_191122_W8
Card #5: Radeon RX 5700 XT 8176 MB · XFX Micron GDDR6 113-230LNAVIXT612_8GD6_MS_W8
Card #6: Radeon RX 5700 XT 8176 MB · XFX Samsung GDDR6 113-230LNAVIXT612_8GD6_MS_W8
Card #7: Radeon RX 5700 XT 8176 MB · XFX Micron GDDR6 113-230LNAVIXT612_8GD6_MS_W8
With all that out of the way, I have a question about using MPT. I found a guide to use MPT to further modify the bios of each card (https://voskcointalk.com/t/rx-5700-bios-modding-guide/5063). However, it seems that I cannot obtain the MPT file in the first place. In other words, I do not know how to go about creating or otherwise obtaining the MPT file in the first place. I was thinking that I could somehow create the MPT file from the original bios image (or from the RBE modified bios image) as the default values would be untouched at this point.
I have searched Google for guides on how to use MPT, but it seems that “it just works” or somehow MPT is being used for a card that is already plugged into a Windows machine.
Am I missing something?
Thanks!
And PS: Is it really necessary for me to create a modified bios image for each card or will one bios image work for all the cards, regardless of the differences in the descriptions of the cards?
