Hi there,
building my 4th mining rig and I have encountered weird issue that I just cannot get rid off. Right at the start of mining, I can have settings on all xfx 470 8gb card set to 1100cr, 900cvol, 1950mem, and for a solid 60-90min miner works perfectly, 0 invalid shares, no temperature issues, nothing.
However after this 60-90min mark invalid shares start popping up on these cards. No matter the settings. I can literally change it to 1050/970/1900 the problem persists. TeamRedMiner doesnt show any rejected shares, all accepted, hashrate on pool functioning OK. any ideas? please
Update: I take it back, TRM shows HW: number of invalid shares.
Getting rid of all OC doesn’t solve issue either - even though cvol goes to 1000 on some cards
The only thing I did was change to phoenix miner, rebooted and instantly getting only good shares 22 minutes in. Gonna update when first invalids come.
Hi, how are you? I wanted to ask you if you found a solution to the problem, because the same thing happens to me with an XFX rx580 8gb with the same Hynix memory
I have almost %50 invalid shares XFX RX 480 8 GB Samsung memory. I also changed many client (Phoenix, gminer, lol) but does not fix ( with or without OC and BIOS)
hi man, i got problem with 470 and i see i got the same model as You
how do You get 28 mh ? i have the same settings and i get only 22
what is the problem ? i got the cards day ago
pls check and let me know
Maybe u forgot REF ? Do you have Modded your bios too?
REF ? were i can do it ?
i didnt do anything with the bios yet,
what version of bios ?
hah, 570 now do 27 mh, the same parameters than before and now its 27
its killing me
kenshinji do you have maybe telegram or smt , can you help me ?
br
sure telegram @kenshinji59
Had the same issue with the same card (Modded xfx rx 470 8gb). Fixed it by keeping the temperature at 50° C. The reason you are having problems is because your card is thermal throttling. Either changed pads/paste or keep the card cool or do both for better results.
I had the same issue with XFX RX 470. Deleted --REF 30 parameter in HiveOS solved the issue. Now I have 1.5 Mh per card less but stable. My settings are CORE 1100 Core Voltage 830 Mem 2000. I get currently 28.5 Mh per card.
