I have a 6 gpu setup with only AMD cards, see below. The issue is that card nr 3 seems to have wrong info on fan speed and possibly wattage?
It seems like 74% fan speed is the max it can go. I have tried to manually set it higher, but it wont show any higher. And can the wattage really be that low??
Anyone else have similar issus?
