Hi. My Rig is online and working good but I cant connect with interface the.hiveos.farm from my home wifi (Server is not responding).
When I switch internet connection on mobile network on the same device then I can SignIn on my Rig.
When I use home wifi I have access only by internal IP.
I talked with provider of internet and they dont see any problem.
Thx I will do that. Now when I log in I get this information: 403 Forbidden.
If your router does not connect with the hive then you need to reset your router so that it can work properly. If after resetting it does not work then you have to switch your router with Linksys router to enjoy the high-speed internet connectivity. If you are new to this router and you cannot access it then you need to visit this link Linksys Router Access to know how you can get access with this router.
Please check the IP, maybe it was banned. I faced some server issues also, more than that my windows also having an issue. error 0x80248007 is showing at the time of work. I think the provider can’t help you. Better to change the IP address.
