Why did my fan speed go to 0% after starting fancontrol service
Hi, I am a mining newbie. I have a small rig with two Amd RX6600s. Everthing was working fine until I installed lm-sensors and fancontrol in order to change my system fan settings. After starting the fancontrol service I noticed that my dashboard doesn’t report fan speed anymore eventhough they are running fine. I tried stopping the service but that didn’t help. I also ran amd-info in the terminal and it also says that the fans are at 0%. Could somebody please help me out.
Thanks!
Usually you can control the system fan speed from within your BIOS. If hive os no longer shows the fan speed of your cards, then is it most likely a issue caused by whatever you did.
Thanks, I was trying to control it without having to shut off the system…
