Web captive portal Wifi and Ethernet help
Hello only chance to connect my rig with internet is via web captive portal with username and password. Please iam in terminal in hiveos with ethernet or wifi on but wifi act like its normal wifi so only put password and it doesnt work. Can somone help me how to connect into web captive portal in hiveos?
Hello Mytthie,
I was having the same issue and I ran with this solution.
An easy solution for you would be to get another computer (your laptop) and connect to the captive portal normally, once you’re in you could copy the Mac address you used and change it on the hiveos terminal, then run hello again with out restarting and you should be fine.
How to change Mac Adress on Linux?
Use method # 2
