I would like to know how to undervoltage my ColorPower RXs, one have lower power consumption and more hashrate than second and both have the same settings. Is possible to make ~120W and 58.5-59MH/s per card and does my setting are actually good, will not brick GPU for some months?
Have you tried to measure the power meter? How much does your car really consume?
Samsung did not manage to overclock as well as micron, but it has the advantage that it consumes less.
Show me micron straps
A good overclocking result for how many days has it been stable?
the wattage shown is totally nonsense and random. you need to measure at wall to get your real power consumption…unless you dont, you cant verify undervoltage.
best way to save some watts is to reduce soc clock speed
About 7 days its working and stable. I know thats not real power comps but i know at wall its +/-65W addtional.
if one card shows 95 and the other shows 125
this does not mean that it actually consumes much less.
you were asked to reduce the frequency of Soc.
show me the bios from one and the other card, and we will look for why such a gap in consumption.
2 questions.
1 card is really Saphire. or a card from another manufacturer but the BIOS is loaded from Saphire.
2 reduce the memory frequency to 912. hash will fall but check how much consumption will decrease?
From micron:
- 1000MHz - 40060000550C0000000000004A090000400000000F19110B28000F00040400020C0000000506060010000000218A05000000010101000101001718006C0700000A0A000078000000780000008A204C02320000000A00040A0E0300011F2A0C006E000000C2F2130F6E00000000000000
- 1250MHz - 0008000065000000000000005A090000400200001120150F33001300060600020C0000000507070014000000210C0600000001010100010100191800470900000A0A000096000000960000008A205C02400000000A00040A100300011F2A0C008A00000082F3130F8A00000000000000
- 1550 MHz and others - 800900007D040000000000006A09000040020000142619133D00170006060002100000000508080018000000218E06000000010101000101001C1800661700000A0A0000B4000000B40000008A206C024C0000000A00040A130300011F2A0C00A500000002F4130FA500000000000000
From samsung:
- 1000MHz - 000000005E0C000000000000DA08000040000000101E0F092D000F0004040002100000000606060010000000110806000000010101000101001718006C0700000A0A000078000000780000004A5156023C0000000C000A0A0F0400011F2A0C00780000004AF3130F7800000000000000
- 1250MHz - 000000007E000000000000006A090000400200001426130D3900130006060002140000000607070014000000218A06000000010101000101001B1800470900000D0D000096000000960000004D5166024B0000000C000A0D130400011F2A0C00960000000AF4130F9600000000000000
- 1500/1800/2000/2250MHz - 000000000F040000000000007A09000040030000162D170F4400170006060002180000000708080018000000210C07000000010101000101001C1800661700000F0F0000B4000000B40000004F5178025A0000000C000A0F150500011F2A0C00B4000000CBF4130FB400000000000000
I set memory frequency on 912 and third card(ATI samsung memory) get crashed and miner shut down.
samsung very rarely keeps such frequencies,
how consumption per micron has changed.
and check what frequency it actually sets
amd-info
about 120w per micron
Tue Dec 15 15:19:46 CET 2020
=== GPU 0, 03:00.0 Radeon RX 5700 XT 111 ===
- Adapter 0: PCI 3:0:0: Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
Core: 1470 MHz, Mem: 945 MHz, CoreOD: 0, MemOD: 0, Vddc: 756 mV
SOC: 1085 MHz, DCEF: 506 MHz, FClock: 1085 MHz
PerfCtrl: manual, Load: 99%, MemLoad: 98%
Temp: 40°C, T2: 46°C, T3: 72°C, Fan: 63.9216%
Power: 122 W (cap: 190 W)
Core Clocks: 300 885 1470
Memory Clocks: 100 500 625 945
SOC Clocks: 506 1085 1266
DCEF Clocks: 506 886 1266
F Clocks: 506 1085 1266
Temps : GPU: 40C HotSpot: 46C Mem: 72C
Memory total: 8176.00 MB, used: 4171.49 MB, free: 4004.51 MB
DPM 2 CORE 1470Mhz 756mV MDPM 3 MEM 945Mhz REF PWR 122.0 W RPM 2323
=== GPU 1, 07:00.0 Radeon RX 5700 XT 111 ===
- Adapter 1: PCI 7:0:0: Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
Temp: 39°C, T2: 45°C, T3: 70°C, Fan: 64.7059%
Power: 126 W (cap: 190 W)
Temps : GPU: 39C HotSpot: 45C Mem: 70C
Memory total: 8176.00 MB, used: 4171.50 MB, free: 4004.50 MB
DPM 2 CORE 1470Mhz 756mV MDPM 3 MEM 945Mhz REF PWR 126.0 W RPM 2341
=== GPU 2, 0b:00.0 Radeon RX 5700 XT 113-D1820501-101 ===
- Adapter 2: PCI 11:0:0: Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
Core: 1420 MHz, Mem: 910 MHz, CoreOD: 0, MemOD: 0, Vddc: 750 mV
Temp: 42°C, T2: 50°C, T3: 62°C, Fan: 50.9804%
Power: 98 W (cap: 180 W)
Core Clocks: 300 860 1420
Memory Clocks: 100 500 625 910
Temps : GPU: 42C HotSpot: 50C Mem: 62C
DPM 2 CORE 1420Mhz 750mV MDPM 3 MEM 910Mhz REF PWR 98.0 W RPM 2530
=== GPU 0, 03:00.0 Radeon RX 5700 XT 113-EXT900128-L04 ===
Core: 1425 MHz, Mem: 912 MHz, CoreOD: 0, MemOD: 0, Vddc: 768 mV
SOC: 950 MHz, DCEF: 506 MHz, FClock: 950 MHz
Temp: 51°C, T2: 59°C, T3: 72°C, Fan: 52.9412%
Power: 118 W (cap: 180 W)
Core Clocks: 300 862 1425
Memory Clocks: 100 500 725 912
SOC Clocks: 506 728 950
F Clocks: 506 728 950
Temps : GPU: 51C HotSpot: 59C Mem: 72C
PCIE Link speed : 5GT/s, PCIE Link width : x1
Memory total: 8176.00 MB, used: 4112.58 MB, free: 4063.42 MB
VDDCR_SOC : 0.77500V, MVDDC : 1.3031V
DPM 2 CORE 1425Mhz 768mV MDPM 3 MEM 912Mhz REF PWR 118.0 W RPM 1863
!!! SOC: 950 MHz
I didn’t bother to squeeze out the last MH.
my micron memory is not stable at 930. at 925 it can work for several days. then job loss.
I turned the frequency down to 912 then SOC do not go higher. But in the BIOS, I registered the maximum frequency.
it gave a little savings.
I have modded bios, maybe that’s the reason of problem. I really dont know, this card is PowerColor Red Dragon if it would help somehow.
So what should i do…
set 912 to micron memory.
check amd-info
What frequency does SOC work on?
Did you lower it to the BIOS?
reduce consumption to 98 how samsung works you probably won’t succeed, but 10-15 watts can be removed.
Core: 1440 MHz, Mem: 912 MHz, CoreOD: 0, MemOD: 0, Vddc: 756 mV
SOC: 1266 MHz, DCEF: 506 MHz, FClock: 1266 MHz
Temp: 40°C, T2: 48°C, T3: 68°C, Fan: 63.9216%
Power: 124 W (cap: 190 W)
Core Clocks: 300 870 1440
Memory Clocks: 100 500 625 912
SOC Clocks: 506 886 1266
Temps : GPU: 40C HotSpot: 48C Mem: 68C
DPM 2 CORE 1440Mhz 756mV MDPM 3 MEM 912Mhz REF PWR 124.0 W RPM 2323
Temp: 39°C, T2: 46°C, T3: 70°C, Fan: 64.7059%
Power: 127 W (cap: 190 W)
Temps : GPU: 39C HotSpot: 46C Mem: 70C
DPM 2 CORE 1440Mhz 756mV MDPM 3 MEM 912Mhz REF PWR 127.0 W RPM 2346
Core: 1420 MHz, Mem: 900 MHz, CoreOD: 0, MemOD: 0, Vddc: 750 mV
Temp: 42°C, T2: 51°C, T3: 62°C, Fan: 50.9804%
Power: 100 W (cap: 180 W)
Memory Clocks: 100 500 625 900
SOC Clocks: 506 950 1266
F Clocks: 506 950 1266
Temps : GPU: 42C HotSpot: 51C Mem: 62C
DPM 2 CORE 1420Mhz 750mV MDPM 3 MEM 900Mhz REF PWR 100.0 W RPM 2535
this once again confirms that you did not reduce the SOC frequency in the BIOS.
you need to set the maximum frequency of soc 950 in the BIOS editor, reduce the voltage of soc.
maximum voltage soc.
You mean OC? And what voltage should i set?
I’ll drop you a video there, everything is well described.
The essence, I think, will be clear, at different voltages and at different frequencies you can see what hash and consumption you can get.
I recommend choosing the best option for yourself and stitching it into the BIOS.
это модифицированный или оригинальный биос?
