Vega 64 Ultimate Guide 56-55 Mhash 130W
Going to try to get to see if I can use the 56 on it…
:+1:
And they are all flashed to 56? Even the asus strix ?
Can you post their hashrate/temp/wattage?
Thanks for your attention btw.
Your vega does 180mh/s with stock bios. What is it’s tdp? (wattage, power consumption)
This is what i use…
Around 130w power consumption
Is around 170/180’s Mh/s
Here:
Straps:
You can see the OC in the image.
This time… went well…
Flash the 56 Bios that you told me to do…
Many many thanks
:slight_smile:
But if i push the core to 1440
TRM says: GPU dead…
(you don’t understand any of this, go fishing) :rofl: :joy:
The card is between 180.6 - 196.1Mh/s
The Nvidia GTX 1080ti is constant at 97.84Mh/s…
And maybe i need to change the thermal pads… big difference in temperature…
I use the Tweaks that you post…
Thanks guys.
So, i am about to buy two reference vega 64’s. One is sapphire reference and the other is xfx reference.
Are they good? Flash-able?
The sapphire vega you guys are mentioning is the nitro+ right? Does the reference works well too(mh/wattage)? (does it work with same straps ? maybe same OC?)
Sapphire Vega 64 Nitro+
with
Bios from Sapphire Vega 56 Nitro+ from akosi post
until now is ok…
Flashed with HiveOS really easy…
but im still playing with the OC…
glad it worked well with you.
well 196 is the sweet spot you want to be.
its only 4 megahash away from 200.
glad to see it working on a lesser wattage.
I don’t know… But I have to see what is happening… In 8h I get 2 reboots…
:thinking:
I noticed the same with the latest hiveos version; I downgraded it to one version lower and it is stable again 24/7.
New update from my vega 64 nitro +…
Using bios vega 56 nitro +
203.3MH/s…
After a get a hammer and almost…
Almost…
:joy: hit the pc …
A monster card… Or maybe the mighty Hammer…
:joy:
maybe they will make a update for that…
if tomorrow is the same going to downgrade too…
how do you downgrade from an updated hiveos?
Also can you share the OC and straps you used for your 203 mhash.
Planning to mine ergo in winter, when ethereum is almost dead lol
Yeah i feel you,
You gonna scratch your head a lot and wait 1-2 hours for another crash just to test if your straps or OC are stable. Sometimes i sleep around 2 am still figuring which of the card is giving me crashes.
vega cards are challenging but once you get them going it’s fulfilling lol
Core Clock, Mhz
1440
Core Voltage, mV
943
Memory Clock, Mhz
960
FAN, %
80  >>>>>>>>I have the Fan 100%
amdmemtweak
–CL 20 --RAS 20 --RCDRD 12 --RCDWR 12 --RC 36 --RP 11 --RRDS 3 --RRDL 6 --RTP 5 --FAW 12 --CWL 8 --WTRS 4 --WTRL 9 --WR 14
Go HERE to downgrade version of HiveOS
Thanks man. Yeah higher voltage and core really gets your gpu very hot.
Make a test…
Fan around 75%…
This is what I have on the card…
nitro + are the coolest vegas ever,
this thing was assembled well.
I mine ethereum and only set fan at 70%
yes, i have one of those in my vega rig, its a monster & runs cooool :slight_smile:
