Hi !
i was consumming 1463 W (wall) with my optimazed rig (10 * AMD-RX580) under 0.5-54 then with the upgrade the wall consumption increase up to 1650W under 0.5-55 !
Also, the cards were consuming around 95 W each (sensor) and before it was around 80 W.
With the 0.5-56 and a reboot … It’s still the same !
What happens ? Am i alone in this case ?
PS : During the same working station, i tried dual mining and also with a second miner, AND i upgraded from 54 to 55. When i saw the power issue, i returned to the precedent miner (no dual, no second miner) but i’m still under v0.5-55. The power consumption is still increased. I downgrade to see if it’s really the new version wich is responsible, and i confirm, under v54 everything is alright !
PPS : I changed nothing to the OC params …
