Using the Pill on a multi card rig
Hi all, I’m running a 3080, 3090, 1080 and 1080ti and having issues trying to set the pill on only the 1080s. I’ve used --revA 3,4 in the command but it seems to set different things on each card. Any help would be appreciated.
Also would like to know. Same type of setup and the pill seems to be enabled on all the other cards individual oc settings page once you enable on the 1080. Also get errors when trying to enable the pill in the miner. Not sure if the command line parm and delay need to be set or not.
Mine does the same thing. Any update to this?
