Using my miner as an Ethereum node?
currently I’m using PhoenixMiner. (yes I heard the code moved and everyone should panic)
I’m not stuck on using phoenixminer, but I would like to use my miner as a node (to submit tx \ query blockchain), and wondering if there’s some flag I have to turn, or its not quite that simple.
Ideally I could keep using HiveOS and Phoenixminer, but I am not trying to spin up the node and run a solo-miner on that… hopefully some popularly used mining software already includes a way to do this.
Thx
Hi, did you find a solution ? I am interested. Thank you
