Hi everyone,
I am facing an issue mining in Hive OS with an unusual low hash rate for GPU 0, GPU 1 and GPU 2. These are all AMD RX 580’s.
The remaining GPU’s (GPU3, GPU4, GPU5, GPU6 etc.) also drop to around the same hash rate every so often for a short time but then shoot back up to approx. 27 M/H.
I’m using the following overclock settings: Cclock 1000, mclock 2160 for the 8GB cards and cclock 1000 mclock 1760 for the 4GB Cards.
I was able to get a constant stable hash rate of around approx. 27 M/H for most of these cards in Windows and also do not get my cards overheating to 70C+ like they do in Hive OS.
But for some reason when using Hive OS i can’t get the hash rate for GPU 0, GPU 1 and 2 to go up to what it should be where it’s almost like the cards overclock settings are not being applied as they’re hashing at such a low rate.
I’ve tried the following already myself:
+setting the overclock settings and assigning to the rig, rebooting rig, still same result.
+setting up an overclock profile assigning it to the rig, rebooting rig, still same result.
+using the claymore config override with my overclock settings, rebooting rig, still same result.
+Tried changing overclock settings and underclocking as well, then rebooting the rig with no change in the Hash rate for GPU0, GPU 1 and GPU 3.
Has anyone else faced this issue? Does anyone have any recommendations of things to try to fix this issue?
Many thanks!
