Hi, i have problem with OC in Hiveos.
It was hard to find stable miner in Hive but it seems i must use ethminer because phoenix and claymore was unstable after vhile.
On ethminer my rig is working for hours but when i want to change clocks or voltage rig gone offline and i must restart him manualy.
I am using Hive beta 0.6-151@200812.
Do you have a tip for better miner, better experiences with some setup or i should try mine at Windows ?
These cards should have hashrate around 38-40 Mh/s.
My rig:
MB: MSI B360-F PRO
GPU: 10x XFX Radeon RX 5600 XT THICC II Pro 6G
CPU: Intel Pentium Gold G5420
RAM: HyperX 8GB 2666MHz DDR4 CL13 Predator
PSU: 2x Corsair HX1200
USB stick: Patriot Supersonic Boost XT 32GB
SW: 0.6-151@200812
