Did anyone have any luck changing the settings or lowering the Voltage on a Radeon Pro Duo?
Hive OS sees the card as two GPUs, each showing “Unknown GPU 1002-67c4r00”.
Whenever I change the OC settings on one of the GPUs, the card will not mine. I tried to change it on both, same thing.
Did anyone have any luck with these cards on Hive OS? I’m currently getting 24 MH per GPU, which isn’t bad, but it’s drawing 200watts, which I really need to lower.
