omg thatās really a bug. You PLād at 150 and itās locked at 214
Iāll try that, thanks
So yeah, i found it super weird that i had to put pl150.
But it worked for me in phoenix and t-rex. Nothing else would work. I saw a ton of people on youtube showing this āfixā.
Also, if you do any overclocks on the card in the rig the msi card with the 150 pl will start going crazy. So after you change anything, even the fan %, reboot the rig.
I didnt set a time before the oc is applied, it worked for me
Yeah, it was stuck at 200 flat before, i even tried flashing the suprim bios, nothing helped
nop, canāt make that work. Setting 150PL makes card work at 150W even after reboot.
The behaviour though, is erratic. If I use 800mem, the PL works. If I use 1600mem, the PL works too.
Any other mem value locks the PL to 209.
Did anyone try thermal pads on these cards?
Itās actually not thermal limiting.
You can check it by nvidia-smi -q
Its some BIOS lock or BIOS bug.
Have tried the 94.02.42.00.FB BIOS with and without 150 PL and it does not worked for me.
Core stuck at ~400-500 MHz and it performs horrible.
Hi there. I have other cards that were not thermal limiting, however jumped to 95+MH after applying better pads (gigabyte and asus).
However, on strange thing. These two MSI cards I have, perform with 205W at 95MH and 91MH. But they produce more shares in ethash than any other card at 97-99MH. This canāt be a coincidence, somehow these cards outperform the others even with lower hashrate. And no, none have rejected shares.
Any ideas?
Ok forget about this, after running for 2 days, the share rate is proporcional to the hashrate.
There is still no way to push the āMSI Gaming X Trioā power to more than 210w.
@jano28 do you have exactly āmsi gaming x trio 3080ā ?
Check this
Basically the same as I said. Works OK with EVGA bios, but its strange that why it pulls most of the power from #1 8-pin. I noticed this behavior too. With my Strix, load is split nicely between the 3x8 pins. Maybe improper VRM design. Maybe memory chips use the #1 8-pin and when you push them hard it hits the limit. That would explains the power limit thing.
Successfully raise the hashrate to 100 on the MSI Gaming X Trio?
Pit
Use EVGA XC3 bios as you can read in the topic.
Iām trying, and I have switched VBIOSes a few times, but currently Iām having a hang in the process.
It stays forever like this:
Stopping services
Unload modules successfull
NVIDIA Firmware Update Utility (Version 5.692.0)
Copyright Ā© 1993-2021, NVIDIA Corporation. All rights reserved.Adapter: GeForce RTX 3080 (10DE,2206,1462,3897) S:00,B:07,D:00,F:00
EEPROM ID (C2,2534) : MX MX25U8033E-MX25U8035F 1.65-2.0V 8192Kx1S, page
Setting EEPROM software protect settingā¦
Setting EEPROM protection complete.
Any ideas on what it might be ? Thanks
i can confirm that Asus rog strix 3080 oc bios works perfect, watt usage is misleading.
can go all way up to 105mh on hiveos, can still touch the backplate
So you can use this bios on the MSI GeForce RTX 3080 SUPRIM X 10GB?
only ask as ive just bought one :-))
cheers
Suprim doesnāt have the powersensors bug. Just pad it and enjoy
Awesome Thx
1100 core 2400 mem 0 pl 110 wat 61.50mh low heat
Hey man
Is that a stock bios that youre using msi 3080 to get 100 mhs?
