I just tried to log into Shell In A Box using the default user and 1 for the password and it said incorrect login. I have a feeling I accidentally reset the password. How do I find the password or reset it.
You can view the password in the root directory /hive-config/vnc-password.txt. You can use vim or vi if you donât have vim installed to update that text file.
where can i get the root directory?
hi my problem, canât login via shellinabox
password: 1
but always fail, what should I do?
can you help me?
You can change password of âuserâ by using the command hive-password yournewpassword .
Instead of yournewpassword you should enter your new password.
For more information, you can check the details from following link: Hiveos Security
username (user) is correct but u have to find password in rig setting of hiveos
HOW? TY
Firstly you can access the shell with the default login name user and default password 1
Then when you access the shell, you can use hive-password yournewpassword command to change your password.
How to acess the shell?
