Trouble shooting Hash Drops.. With Error Codes
So I’m trying to trouble shoot these codes. I’m almost sure it’s pointing at GPU-0 But I’m not sure what it’s saying other than perhaps the overclocks are causing it to possibly over heat, and drop & reboot ?? Any help would be appreciated.
Jun 10 15:03:43 kernel: NVRM: Xid (PCI:0000:06:00): 62, pid=3613, 0000(0000) 00000000 00000000
Jun 10 15:03:43 kernel: NVRM: Xid (PCI:0000:06:00): 45, pid=3613, Ch 00000010
Match the pcie location in the error to the card and lower the mem clock and reboot. Repeat until stable. (Assuming you’re already running the lowest locked core clock that maintains full hashrate and not a core offset)
So that would be PCI-0 or 6? I’m understanding you, But I’m not sure which one it is. Yes I use lock core… Unfortunate If it’s PCI-0 Then It’s not a lock core cause it’s an A4000 gpu
Pcie 06:00. Look at your overview screen and match it to the card that has 06:00 next to it
Ok, I see what you are pointing to. That’s my 3080ti. Weird because I did suspect it a couple days ago, and changed the settings, this is my current settings
119.9MH Core tmp 52° Mem tmp 84° Fan use 98% Fan Setting 100 Core 1100 MEM 2400
Most people are using this setting with limited issues I thought… What do you guys recommend?
Find the highest mem clock that’s stable. If it’s not stable reduce and reboot
