Hey man, i coudn’t get any ETH hasrate even though i followed all of the steps for HiveOS. Why do you think that is? Thanks for advices in advance.
Change “kawpaw” to “kawpow”.
Everything else looks ok to me.
I test T-rex on 3x3080TI mining ETH+CFX. Here is screenshot:
Both hashrates fluctuate. Eth in range 29-41 while CFX in range 69-82.
Overclocking doesn’t look to have influence on hashrate. It doesn’t matter if I set C1140M2700 or C1500M3000. The only difference beetwen these two is power usage.
Nice info. Thanks! I have questions.
Your overclock profile is aiming toward the algo1 or algo2(lhr_algo)? Let’s say If I want to dual mine eth+erg, which overclock profile should I use, eth or erg?
Does the order matter for algo1 and algo2? For example, is eth+rvn and rvn+eth will have the same result?
Thanks in advance.
- From my testing OC aim for a more difficult coin. For example for ergo which is a very sensitive coin, we should find the OC parameter for each card for stable single Ergo mining first before Dual.
If ergo LHR trigger, will also trigger ETH.
For Eth + RVN we aim for eth, because rvn didn’t trigger LHR.
- Order doesn’t matter, I tried set flight sheet for rvn and add extra config for Eth miner still behaves the same.
Cheers
Yeah I think ETH+CFX pair is way more stable, now testing on 3060 LHR V2.
hi
noob questions
Where to find “url2” ?
it’s out adress ravencoin for exemple in “user2” ?
This is pool address where you want to mine RVN with exact port. If you have flightsheet for mining rvn you find it there. Check Server URLs
thanks a lot man. work good now
yep exactly thanks !
Thanks for the Info about the 24.2 version I just did thse command modified and it work! Have fun…
cd /hive/miners/t-rex/
mkdir 0.24.2
cd 0.24.2
wget https://github.com/trexminer/T-Rex/releases/download/0.24.2/t-rex-0.24.2-linux.tar.gz
tar -xzf t-rex-0.24.2-linux.tar.gz
cd …/0.24.0
mv t-rex t-rex.old
ln -s …/0.24.2/t-rex .
I have the same issue and I may be just dumb but how does one go about correcting inverted commas? I tried to type it out in a word doc while being able to see the proper orientation of the commas and then copy paste to hiveos but still get the same error.
is 0.24.2 not available on hive yet through system update? i just updated yet miner is still running 0.24.0 (i want to use the lhr-autotune-mode :D)
By isolating the LRH cards on trex, I was able to get lhr to 37 without having any lock after 1 hour passed.
It’s still better than 30
Regards
Jbsky
Ho great news I havent played wit it yet, but the 24.2 should try to optimise itself. I will try that to! If only we could see all Hasrate at the same time it would be easyer to tune… Can’t find a way to bind the adresse of the trex api since i am in Hiveos…
Yeah you can update it manually if you want using @nepius way with the update text I have post a few post higer…
could you please re write the code again because this one is not working.
I could but hiveos just updated, its gona be easyer for all! Happy Dual Mining
Yes they did still hanging with 3080 and 3070 ti Eth / RVN after try every code in earth i reach to :
Mining at eu1.ethermine.org:4444, diff: 4.29 G
GPU #0: RTX 3080 - 42.09 MH/s, [LHR 38<>] [T:43C, P:199W, F:70%, E:212kH/W], 12/12 R:0% I:0%
GPU #3: RTX 3070 Ti - 30.86 MH/s, [LHR 44<>] [T:46C, P:169W, F:70%, E:183kH/W], 6/6 R:0% I:0%
GPU #5: RTX 3080 - 40.23 MH/s, [LHR 44<>] [T:33C, P:199W, F:70%, E:202kH/W], 8/8 R:0% I:0%
Hashrate: 113.18 MH/s, Shares/min: 10.563 (Avg. 0.868), Avg.P: 567W, Avg.E: 200kH/W
Max diff share was found by GPU #5, diff: 199.21 G
Uptime: 30 mins | Algo: ethash | T-Rex v0.24.2
---------------------20211011 04:31:33 ---------------------
Mining at stratum-ravencoin.flypool.org:3333, diff: 431.17 M
GPU #0: RTX 3080 - 23.27 MH/s, [LHR 38<>] [T:43C, P:199W, F:70%, E:117kH/W], 62/62 R:0% I:0%
GPU #3: RTX 3070 Ti - 12.72 MH/s, [LHR 44<>] [T:46C, P:169W, F:70%, E:75.3kH/W], 27/27 R:0% I:0%
GPU #5: RTX 3080 - 16.93 MH/s, [LHR 44<>] [T:33C, P:199W, F:70%, E:85.1kH/W], 58/59 R:1.69% I:0%
Hashrate: 52.92 MH/s, Shares/min: 10.488 (Avg. 4.911), Avg.P: 567W, Avg.E: 93.3kH/W
Max diff share was found by GPU #3, diff: 125.53 G
Uptime: 30 mins | Algo: kawpow | T-Rex v0.24.2
better than before for sure.
Happy mining everyone
0.24.2 is now available with latest HiveOS!
