Total hashrate 10894.96 is less than 90 percents of 14142.15, stopping miner
Hello, few days ago I conected my first miner Antminer s9 and from frist day I have this error
There is nothing on google about it, it does not metter if watchdog is on or off, it gives this message every few minutes and restart miner.
Does anyone have some idea what to do ?
Also it goes only up to 4 Th/s on nicehas, I just switched to binance to see is there any change.
What do you have your desired hashrate set as?
It was not setup, i even turned off watchdog. But problem solved after I removed nicehash pool.
Thank you anyway.
